New Long Block Installation ?????? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-07-2010, 02:07 AM Thread Starter
Are there a specific set of procedures to follow when starting a new 7.3 long block and if so does anyone know what they are? I am new to diesels so any help is appreciated. Thank you.
LeeS is offline
post #2 of 18 Old 10-07-2010, 05:01 AM
addicted to diesel
highraven99's Avatar
one thing i can say is to prime the oil rails and the high pressure reservoir with oil by filling them with oil. it will help it start for the first time quicker.
New member map has been set up here:
Diesel fumes make me horny!!!!
Originally Posted by Big Angry Hillbilly View Post
I hear that Dodge gives you a puppy with every truck you buy, so you'll never have to walk home alone again.
highraven99 is offline
post #3 of 18 Old 10-07-2010, 05:39 AM Thread Starter
That can be done through the HPOP right? How much oil is needed? The oil that is used to prime the oil rails and HPOP is that in addition to what is used to fill from empty or is that part of the almost 5 gallons it calls for?
LeeS is offline
post #4 of 18 Old 10-07-2010, 05:41 AM Thread Starter
Sorry through the Oil Reservoir not the HPOP. My bad.
LeeS is offline
post #5 of 18 Old 10-07-2010, 06:35 AM
tekemp's Avatar
the resevoir will take about 3qts if i remember correctly, thats in addition to the 15qts that goes into the motor.
2012 F-350 CCLB XLT/EGR/WEATHERTECH/RIGID/CTS/
tekemp is offline
post #6 of 18 Old 10-07-2010, 07:27 AM
ridiculously_necessary's Avatar
iirc, half quart in the resevior, and almost a quart in each rail. but filling the res will not fill the rails automatically. youll have to crank or preload the rails via access port. i beleive if you overfill the res it will just drain to the crank case... can anyone verify this is correct?
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #7 of 18 Old 10-07-2010, 07:50 AM
That's what I understand, it just drains to the pan
2000 F-250 SCLB 7.3 auto 2wd, guages,PHP Phoenix,w-w,4"tb exh
cj45lc is offline
post #8 of 18 Old 10-07-2010, 07:54 AM Thread Starter
Ok so I should fill the oil reservoir through the fill plug and fill the oil rails the the oil rail ports before attempting to crank this beast over?
LeeS is offline
post #9 of 18 Old 10-07-2010, 08:20 AM
It will fire quicker if you do. Probably run rough for little bit til it purges the air out of the system
cj45lc is offline
post #10 of 18 Old 10-07-2010, 08:24 AM Thread Starter
So how much oil should I use in the reservoir? 3 qt or a 1/2 a qt.? Or should I just fill it up to 1" from the top and do the rails separately?
LeeS is offline
