Replace Front Brakes
I replaced my front brakes today, the only thing that I didnt do was unscrew the cap on the reservoir.
My brakes are dragging alittle bit I can hear them as I drive. Any ideas? built up pressure from not unscrewing the cap??? |
Bump for bed
/hijack
you should unscrew the cap? no wonder why my truck pulls to the right.. dangit. oh well warped rotors.. gotta do them again.. now only if i can find my f'n lug key i could have done it today.. but i lost it /serious |
i did no difference
you did push the pistons back into the caliper when the brakes were out? having the cap off or loose will not cause that. more like piston sticking.
Did you clean & lube the slide pins?
What shape are the rotors in? Did you get them turned or are they new?
I agree, sounds like a ceased caliper.
New rotors. did not do anything else but compress the calipers and slap on new pads. They went in without a hitch
X2 on the slide pins. Probably seized up.
