you could probably get new keys at ford without buying new locks.as far as the diff goes,if you have a limited slip you definitely need the additive unless the fluid says its already added,but some people put it in there just for security and piece of mind.the rest i dont know what to tell ya cause im not a suspension guru
having a lift puts more strain on the pitman arm, replaceing them is common. and sounds like they want to to tie rods also a common issue with big tires. but I would do at least the pitman arm my self, it aint that had to do and you can save at least a little. my suggestion is to check the price for the parts at a local parts store and see how much they are compared to the align place. The price they gave you for the camber "slug" aint that bad though. Wifes chevy with 9in lift is alot worse she goes through tie rods, axels and ball joints about every 12,000-15,000 miles. And your steering being off so offten is the cause of the tie rods. Oh and another thing I would have another quote done on it Firestone is always on the high side here. I go with a local shop cause they are the only ones that do duallies. and it sounds like they are cheaper than the price you got. Hell if it was me I would get the parts, do it your self and just bring it back to firestone and have them adj it for you tie rods are the ez thing on the front of these trucks.
BTW 9.10% sales tax is bad makes me glad to only have 7.4% and I thought that was bad! Ok now I am done lol |
Yes just get a new key cut at ford. If you need a new cylinder they can key that the same also.
also i heard to use MOOG K80109 part since its an adjustable camber |
not using the additive in the oil with posi will make it chatter going around corners. more than likely your posi is worn out. they were junk straight off the dealers lot. you can rebuild the posi and change the position of the shims and clutches to get more bite. i did that with my 03 and it made a huge difference.....
so. i had to redo my brakes tonight.. (2 months old) and noticed driver lower ball joint moves, so my knuckle moves about 2/8 of an inch
That too much movement. Time to replace ALL the ball joints.
why all? the other side is good and the top is good on the driver. i noticed the wheel moving side to side when the tech was driving it str8 after an alignment couple months ago.. finally had my tire off and checked them
They all have the same amt of miles right? Usually the rest are not far behind. If I was replacing one I would do them all. Or you will do one now and 6 months later another etc etc. Thats why the steering keeps going out of center,can not be properly aligned when there are loose components.
