how to remove fuel line from pump??
ok i have to change my frame mounted fuel pump this afternoon and before i do i want to make sure there are no odd tips or tricks i should know, i tried to remove the fuel line earlier and it had a quick disconnect i havnt seen before. i took the clip off and tugged a little but didnt put alot of @ss behind it because i didnt want to break it. is there a special tool or should i just try to rip it off haha
if ya havent done it yet: usually the back connector you pull the hairpin clip out and give it a little tug. the front one uses a special tool that slides into the connector and pushes a spring and catches out. once the tool is engaged right it takes a little force to seperate.
Should be a yellow fuel line tool
how could i go about getting this tool (or makeing one) and and i wanna say the fuel line coming from on top of the motor is blue
Auto parts store.
