Starting and charging problems with battery drain - Ford Powerstroke Diesel Forum
Old 10-05-2010, 08:46 AM
I tried to jump my excursion yesterday and finally got it started. It ran fine and then I shut it off for the evening. I immediately metered the battery as it was resting and the voltage was 11.95. This morning I went out and metered it and it said 4 volts! Now I know no interior or exterior lights were left on as I double checked last night after shutting everything off. Is there a way to test and see if there is a short circuit? I was thinking of switching the Multimeter to amps to see if there was current draw and then individually removing fuses until the problem subsides. Anyone have any ideas? I really don't have the money right now to take it to a shop so this is something I need to fix on my own. Thanks agai.
Old 10-05-2010, 09:07 AM
Have the alternator checked, maybe the voltage regulator is stuck open.
Old 10-05-2010, 09:20 AM
Thats a good call but I already did that two days ago and autozone claims it passed their test with flying colors. I did meter the output voltage a few times and it was all over the place at idle; ranging from 12.6volts to 13.5 volts and it peaked at 13.9 volts when I had my lady rev the engine to 2000rpm.
Old 10-05-2010, 09:49 AM
The batts should be closer to 12.5 when you first shut it off, the alt should be close to 14.5. If it was me I'd unhook the alt overnight & check batts in the am. Sounds like alt to me
Old 10-05-2010, 11:21 AM
Your alternator will still charge fine, but if the regulator is stuck open it will let the batteries drain. I went through the same thing with mine and thats what it ended up being. Bought a new alternator and all is good. Hope you get it fixed soon.
Old 10-05-2010, 11:25 AM
I should have paid more attention to this. If your not above 14.0 volts your alternator is junk. These trucks are pickey from what I've noticed about voltage output.
Old 10-05-2010, 11:26 AM
Thanks for all of your help guys
Old 10-05-2010, 12:02 PM
No problem. Welcome to the ORG
Old 10-05-2010, 01:35 PM
What's a good brand of alternator to use to replace the existing one?
Old 10-05-2010, 02:14 PM
Not AutoZone.
