Recall Notice : Camshaft Position Sensor - Ford Powerstroke Diesel Forum
Old 10-05-2010, 05:41 AM
Anyone else get a recall for Camshaft Position Sensor (CMP)? I have a 00' F250 and have had it for about a year and looking at the symtoms for a bad CMP, my truck sure does fit the description. Anyone know how long this service takes, what's all involved?
Symptoms
•A failed camshaft position sensor will show up in a number of ways. The worst-case scenario is that there is no spark in the combustion chamber. Other symptoms can include excessively long cranking time when starting cold, rough running on an intermittent basis, poor idle, stumbling or hesitation, a drop in mileage and stalling upon acceleration. These symptoms may also be caused by a failure in the wiring of the sensor.
Read more: Camshaft Position Sensor Failure Symptoms | eHow.com Camshaft Position Sensor Failure Symptoms | eHow.com
SUBJECT: Safety Recall 07S57:
Certain 1997 - 2003 F-Super Duty, Excursion, and E-Series Vehicles
Equipped with 7.3L Diesel Engines
Camshaft Position (CMP) Sensor Inspection / Replacement
AFFECTED VEHICLES
Vehicle Line Model Years Assembly Plant Production Dates
Econoline 1997-2003 Lorain Assembly Plant 4/3/1996 - 9/16/2003
Excursion 2000-2003 Kentucky Truck Plant 3/25/1999 - 11/1/2002
F650/750 Series 2000-2003 Cuautitlan Assembly Plant 1/20/1999 - 10/31/2002
F-Series 1997 Kentucky Truck Plant 6/18/1996 - 12/17/1997
F-Series 1997 Cuautitlan Assembly Plant 6/11/1996 - 12/10/1997
F-Series 1999-2003 Kentucky Truck Plant 9/3/1997 - 11/4/2002
F-Series 1999-2003 Cuautitlan Assembly Plant 10/2/1998 - 7/21/2003
Affected vehicles are identified in OASIS. In addition, for a list of vehicles assigned to your dealership,
REASON FOR THIS SAFETY RECALL
In some of the affected vehicles, the Camshaft Position (CMP) Sensor may fail due to circuit
degradation. If the CMP Sensor should fail, the engine may stall. In the event of an engine stall, a
crash could result without warning. A new CMP Sensor with improved reliability is now available.
SERVICE ACTION
Dealers are to inspect the CMP Sensor to verify which design level sensor is installed in the affected
vehicles, and replace all prior level sensors. This service must be performed on affected vehicles at no
charge to the vehicle owner.
OWNER NOTIFICATION MAILING SCHEDULE
Parts to repair this condition are currently not available in sufficient quantities to service all of the
affected vehicles. Therefore, to ensure that an ample supply of parts is available, owners of affected
vehicles will be notified in separate phase mailings over several months. Phase mailing will begin the
week of December 17, 2007; prioritized by age of vehicle. Dealers should repair any affected vehicles
that arrive at their dealerships, whether or not the customer has received a letter.
OWNER REFUNDS
Ford Motor Company is offering a refund for owner-paid repairs covered by this recall if the
repair was performed prior to the date indicated in the reimbursement plan, which is posted with
this bulletin.
Dealers are also authorized to refund owner-paid emergency repairs that were performed away
PARTS REQUIREMENTS / ORDERING INFORMATION
The Camshaft Position (CMP) Sensor will be 'seed stocked' to dealers.
F7TZ-12K073-B Camshaft Position (CMP) Sensor
Old 10-05-2010, 05:44 AM
Almostdunfukinwidit
That recall has been around for 2-3 years. Surprised you are just getting the notice now
Old 10-05-2010, 05:47 AM
Almostdunfukinwidit
Symptoms
AFFECTED VEHICLES
SERVICE ACTION
OWNER REFUNDS
this bulletin.
Someone needs to smack Ehow.com
But yes there is a key symptom to the CPS recall. Your truck suddenly dies leaving your stranded on the roadside
Old 10-05-2010, 05:49 AM
Haha, oops! Well I just bouht the truck about a year ago so mabe that's why I'm just getting it.
The symptoms sure match so hopefully this will take it.
Sorry for the super old recall notice. haha
Marc
Old 10-05-2010, 05:52 AM
Most of my trucks symptoms are excessively long cranking time when starting cold, rough running on an intermittent basis, poor idle, stumbling or hesitation, a drop in mileage. Of course the drop in mileage is probably due to the rims and tires.
Old 10-05-2010, 06:02 AM
Almostdunfukinwidit
Crawl under your truck and look
If its gray you have the new one
http://home-and-garden.webshots.com/...38710124WxNHfe
Old 10-05-2010, 03:52 PM
DJM DJM is offline
I ended up putting the original black one back in trucks runs better. They also reflash the computer when they put in the new gray CPS atleast that is what I was told so I never took it in and had them do the recall because I don't want them reflecting anything
Old 10-05-2010, 04:07 PM
yeah I bought my truck with that recall notice in the consol, but i got the notice the other day also. I havnt decided if its worth messin with...... course my truck only has 80k on it..... what will the reflash consist of? better or worse afterward?
Jim
Old 10-05-2010, 04:49 PM
yeah i just got the same letter in the mail the end of last week. what exactly are they gonna do if i take it in? i have a bully dog flash on my ecm and dont wanna loose it.
Old 10-05-2010, 04:56 PM
I found about it when I ran the carfax on my truck and took it in. It took about 10 minutes. They did the cruise control harness while they were at it.
