Transgo which kit to buy?
I have a 01 F250 i pull a small utility trailer 12x8 fully loaded i'm guessing wouldnt weigh more than 4500 pounds would i be alright to put the performance reprogramming kit in it i think the working truck reprogrammer would be a bit over kill for what i tow. Or should i just go with the shift kit... kinda confused
well if you get a custom tuned chip it will prob be the same thing.. the shift kit will boost your line pressure.. but a custom tuned chip will do the same thing....
my suggestion is Gauges first then a custom tuned chip like a TW, PHP or DP if you need any prices let me know... -Raul |
got guages, tru cool tranny cooler... Looking at a dp tuner, is there any thing else i can do to protect the transmission besides a new torque converter just want to keep this one around as long as possible once it goes out going to ats for a new transmission
add a new valve body.. and make sure Jody knows which one you put on... JW and BTS is the ones i would choose
why are you sold on a DP? dont get me wrong they have very good tunes but once you go DP you cant ever switch... everyone else is using the TS style chip... so lets say you got one from a tuner and wanted to try someone elses tunes you could send it in to get reburnt... you wont be able to do that with the DP also if you purchase a TW chip new you get lifetime reburns.. so if you ever decided to get diff tunes or if you some day add new mods like upgraded turbo or injectors you can send it in and get it reburnt for those mods for free... -Raul |
Havent really had any experience with tw know a couple of guys with DP and they work well. Plus more tunes guess that doesnt mean quality tunes but...
get the tugger kit, drill the plate .030 over and dont look back. I bought the tugger kit from summit for $93.00 bucks. I ran a custom valvebody in my lightning so i spent quite a bit of time researching this. The tugger is a complete reprogrammer kit that not only corrects the shift, but also corrects several design flaws of the 4r100.
like wingnuts had mentioned, i had just gotten done spending a lot of time reading and researching a valve body and other parts for my trans because i want to keep it alive for a as long as possible before a rebuild, and that tugger kit is what i have chose to do.
all you have to do is look at a few lightning forums and they all recommend it |
