Glow Plug Relay - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 16 Old 10-01-2010, 07:31 PM
SyN
Lubrication Addict
SyN's Avatar
Stancor / White-Rodgers - 586-903 - Sensors, Switches & Relays - Relays - Allied Electronics
Check this one out!
Had too replace mine this evening... Took about 30 min.
01F250-4WD-XLT-AUTO-CC-7.3L-{295K} Miles
Donaldson AIS Intake System w/Zoodad
4''Turbo Back MBRP Exhaust
Remote Spin-on Coolant Filter/Red {ELC}&RMI-25
Remote Spin-on Transmission Filter/Lg Magnet
203*F T-Stat w/Billet Housing
CCV Re-route
SS HPX Line
Many Other Small Mods
Oil-------->T6 w/Amsoil Filter & Lg Magnet
AMSOIL-------->Every where else
SyN is offline
post #12 of 16 Old 10-02-2010, 08:39 PM
Tempsho's Avatar
Quoted: 3 Post(s)
I am going to go with the Western 56131K-1 relay. For around $13 you can't beat the price! Not too many people run it, but the reviews I've read, I haven't heard any problems with them.
56131K-1 - MOTOR RELAY KIT : :
Western snow plow solenoid motor relay 56131
Tempsho is offline
post #13 of 16 Old 10-03-2010, 04:39 PM Thread Starter
99red7.3's Avatar
I think im going with the big bastard the 903 and also hopes this helps with some of my cold start issues! Thanks for the help guys!
Born 4/99
4X4 6 Speed
05 Front Grill
PHP 6 Position Chip
MBRP 4" TB Exhaust
Foil Delete
DIY Intake
Wicked Wheel
Zoodad
5% Tint
Autometer Boost and Pyro Guages
99red7.3 is offline
post #14 of 16 Old 10-03-2010, 05:18 PM
Stroken7.3's Avatar
You won't be sorry, Good luck.
2001 F-250, 6 speed trans, BDP Tunes, Autometer Ultralite gauges
Stroken7.3 is offline
post #15 of 16 Old 10-03-2010, 05:58 PM
Tempsho's Avatar
Quoted: 3 Post(s)
Resting voltage of a battery is around 12V, so if the coil for the 903 is rated at 15V, it isn't going to pull in and seal as hard as the 902, which is rated at 12V. I don't think you can go wrong with either one.
Considering the Western relay is only $12, I think it would be worth while to give it a try. Nothing but good things i've read about it.
Tempsho is offline
post #16 of 16 Old 10-10-2010, 01:18 PM
Check this one out!
Having the same problem with my pickup, ordered a 902 from Allied there. Use coupon code SAVETEN, and get 10% off.
Oh, and thanks for having the info I needed. Didn't even have to ask a question. Unless this fails to completely fix my cool (it isn't even cold yet) starting problems.
tek9tim is offline
