Odd hesitation while driving - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-27-2010, 08:17 PM Thread Starter
Jay1823's Avatar
So i'm driving down the freeway a couple of weeks ago doing about 65 and all of the sudden i loose all power. Engine is running but i have no power, press the pedal down and nothing. Now if i take my foot of the accelerator completely for a second and put my foot back down it drives like normal. It happens a couple times a week, i have noooo clue what it could be, just thought someone may be able to point me in the right direction in what i might look at. Thanks
Jay1823 is offline
post #2 of 9 Old 09-27-2010, 08:39 PM
do you loose rpm? or does your truck rev up? stick or auto trans?
2000 F250 SD ex cab long bed
6spd trans
south bend 350hp-750lb/ft clutch
6 in lift with 37in Km2 BFG
4in mbrp turbo back single exhaust
TS 6 Pos Chip
DIY intake
SOON TO COME
new injectors
some sort of turbo upgrade
Sullie250 is offline
post #3 of 9 Old 09-27-2010, 08:45 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
no dash lights? changed the cps yet?
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #4 of 9 Old 09-29-2010, 05:57 AM Thread Starter
Jay1823's Avatar
I pretty much loose rpm's, as if you just took your foot of the accelerator. Auto trans. No dash lights, no check engine light. I believe the CPS was changed last year, if your referring to the recall that went out. I have another recall i need to take it in for but that has to do with brake fluid possibly leaking and causing a fire. I remember when the CPS was bad, the truck would just die, were talking freeway speeds, whatever, it would just shut down. So whatever recall that was for fixed that issue.
Jay1823 is offline
post #5 of 9 Old 09-29-2010, 06:05 AM
Mine would do the same thing and I replaced the cps and no issues so far.
12/98 E-99 CC Long Box 4WD Dually Lariat, Banks IC/Wastegate/6-Gun........Heated/Cooled Cupholders
Degnol is offline
post #6 of 9 Old 09-29-2010, 03:09 PM
Hoverp's Avatar
What is the CPS
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
post #7 of 9 Old 09-29-2010, 03:14 PM
ZachBoyer's Avatar
Camshaft Position Sensor
2005 F250 6.0 King Ranch Crew Cab Short Bed 4X4
-MODS-
4" Turbo Back Straight Pipe
Sinister EGR Delete
Sinister Coolant Filter
Cat EC-1 Coolant
ZachBoyer is offline
post #8 of 9 Old 09-29-2010, 07:53 PM
Hoverp's Avatar
Copy, Hard to replace? What do they go for $$?
Thank you
Hoverp is offline
post #9 of 9 Old 09-30-2010, 06:12 AM Thread Starter
Jay1823's Avatar
I'll have to call the dealership and see what they replaced in that last recall i took it in for, if it's not the CPS i'll replace that
Jay1823 is offline
