EGT Gauge - Ford Powerstroke Diesel Forum
Old 09-26-2010, 03:42 PM
EGT Gauge
My EGT gauge is not working correctly. Instead of have some hole in my pillar while i send it back i wanted to make sure it wasnt my probe.
It works great under 600 degrees. over 600 it pegs out at 1500 degrees or bounces around alittle.
any thoughts? Wiring is pretty straight i did alot of tape on the 3 inches of exposed wires and the rest of the wire has a tube over it.
Any ideas wwould be great. Thanks!
Old 09-26-2010, 04:27 PM
get another temp sensor and give it a shot before hand..it sounds like maybe the sending unit may be screwed
Old 09-26-2010, 06:41 PM
K so ill run down to the diesel shop and try swapping out the probe and wire.
Old 10-17-2010, 06:38 PM
so did this work?? im in same situation...........
PS this must have been an Autometer gauge right? What is it with these Autometer EGT gauges anyways?????
Old 10-17-2010, 11:37 PM
I've never had 1 problem with my Autometer gauges in almost 8 years .
Old 10-18-2010, 03:08 AM
check your ground.
Old 10-18-2010, 04:05 AM
Yea has to be a wiring problem. Unless you did just happen to get a bad sending unit
Old 10-18-2010, 05:54 AM
I've had to replace the probes in a couple trucks because they were acting up. Edge probes go out alot, I know yours isn't Edge just saying I wouldn't worry to much. Install new probe you'll be good as new I'll bet.
Old 10-20-2010, 03:38 PM
I vote for the new probe too. My wiring is straight. Ive been pretty lazy about getting it fixed though. ill let yall know wha the outcome is
