Broken leaf or a hack to raising the rear - Ford Powerstroke Diesel Forum
Old 09-25-2010, 07:29 PM
Send a message via AIM to tristanlee85 Send a message via MSN to tristanlee85 Send a message via Yahoo to tristanlee85
I've never messed with leaf springs before, but this just looks wrong. All I can think of is the spring was broken and moved out to possibly raise the rear? I have no idea. It's not even a clean cut. It looks like it was snapped. Both sides are like this:
Ahh the joys of tearing in to the previous owner's toy for the first time.
Old 09-25-2010, 08:00 PM
ya thats a broken spring, your gonna wanna replace that spring or just go with new leaf packs on both sides.
Old 09-25-2010, 08:48 PM
Ahh, so it wasn't a hack. I find it odd they took the time to tape it up though. After I posted this, I noticed whenever I set the wheel back on the ground, there was no tension on the piece anyway... probably the clunking noise I always hear too. Thanks!
Old 09-26-2010, 05:33 PM
It's a break all right,had the same thing in the past on a different truck.
I would replace both spring packs and be done
Old 09-26-2010, 06:45 PM
Is there a particular place I should purchase from? From what I'm told, it just has the leveling kit on it so the rear would be stock height, correct? I have no interest in raising it anymore just yet simply because I already have about .5" clearance to the garage door and would like to keep that for winter maintenance.
Old 09-27-2010, 05:41 PM
The dealer is always the last,but sure place to check due to cost-but always compare,I've bought parts cheaper sometimes from the dealer than after market-it's a toss up sometimes.
I don't know what resources you have locally,but on my side I have Fallsway Spring co. that can make you whatever you want.
Check online - maybe you have something like that near you
Maybe a local junkyard,but if your truck sits level with the front leveling kit-just ask for stock rear springs
Good luck!
Old 09-27-2010, 06:36 PM
OR......................................nows a good time to lift it
Old 09-27-2010, 06:47 PM
Don't know where Jefferson Ohio is but here in Akron there is Stuver Spring . They are a great shop .
Old 09-28-2010, 10:51 AM
Good luck!
Sounds good to me. I figured the dealer had quite a high mark-up, but wasn't sure if there was any vendor or sponsor of the forum or maybe a popular site. I will keep shopping. Thanks.
Now would be a great time to lift it only if I had a garage that would allow it. Maybe when I buy a house.
Jeffersonville is about 30 miles south of Columbus. I will keep them in mind for sure. Thanks.
Old 09-28-2010, 05:09 PM
find a local truck center or spring shop they are usually the cheapest and do that kind of work everyday where i work we send all of our broken springs to the spring shop bc they are so cheap and fast its not even worth doing in house
