Grille only conversion
Hey I can't remember, does the 05+ grilles fit the 99-04 header panel?
I already have the 05+ headlights in and I cut the header panel for them to fit. I'm thinking about just throwing on an 06 black XL grill just to see what it would look like. They are cheap. I don't plan on changing the header or the bumper. I know I have to cut the bottom of the grill for it to fit, but how is it mounted to the header? |
The grill needs to be cut on the bottom to be used with the 99-04 bumper
I already said that
It mounts just the same as the 99-04
What's the best way to attach the bottom after it's cut?
Chris, if that is your truck in the picture on the drag strip... well IMHO, I think it looks awesome with the setup you have...lets folks know that you have a great model year...
I'd go ahead and get a bumper along with it. Just makes it look a whole lot better.
I had no intention of finishing the conversion right now cause of $$, but the grill is so cheap I figured I could put it on there and see if I like it. If I don't I can go back to this grill easy enough.
I think you have to zip tie the bottom of the grill if you don't use the new header panel...
Correct. |
