Map sensor???? - Ford Powerstroke Diesel Forum
Old 09-24-2010, 07:48 AM
Map sensor????
Is it by chance the sensor mounted right next to the oil fill cap on the passenger side with the hose running from it to the intake??? If it is, then the dang clamps on both ends were loose enough that a light pull pulled the hose off the nipple. Low boost issue fixed maybe???
Old 09-24-2010, 09:38 AM
Well, whether it was or wasn't the right hose, it didn't make a difference. The truck still won't move out of it's own way.
