Old 06-10-2007, 07:28 PM
cuidate cuidate is offline
Newbie buying a 2001
I'll be looking at a 2001 F250 7.3 with 104K and I would like to know what to look for in terms of potential problems.
Some friends and some research suggests that this 7.3 is a kind of legendary engine and that's why I'm leaning in that direction.
I have never bought any car or truck with that much mileage on it and so I'm wanting to know what to watch out for.
Old 06-10-2007, 07:43 PM
sldghamr sldghamr is offline
one problem to looks for is your CPS (cam position sensor) going out. it tells the computer what position the engine is in. if it goes out, the engine won't start/studdering/sudden shut downs.
another one to look for, there are four sets of electrical harness under the valve covers that control all 8 injectors (1 for every 2 injecters). the one that controls cylinders 6 and 8 has a design defect (driver side rear two cylinders). Ford fix the problem. don't know when they fixed it, you may have the bad one, it'll go out at random times. mine went out back in January of 2006. smoke was coming out from under the valve cover.
any other problems as far as i can tell are just the user abusing/not taking care of things.
Old 06-10-2007, 07:56 PM
Dave Dave is offline
Obama sucks
Check out this link its got some good things to look for
What to look for when buying a USED 99-03 PSD
