Weird door locks??? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 09-22-2010, 07:28 PM Thread Starter
smokenstroker99's Avatar
Weird door locks???
hey all. i have a weird door lock situation going on and im just looking for some insight. when i try to lock or unlock the doors from the switches nothing happens, not even the slightest movement. however when i hit the unlock on the passenger side both doors unlock but they will not lock from that side. i have checked fuses and the relay under the hood and they are good. . thanks for any help
smokenstroker99 is offline
post #2 of 15 Old 09-22-2010, 07:38 PM
JSchuricht's Avatar
I would start by pulling the DS switch apart and cleaning the internal contacts with WD40.
JSchuricht is offline
post #3 of 15 Old 09-22-2010, 07:44 PM Thread Starter
DS switch?
post #4 of 15 Old 09-22-2010, 07:46 PM
JSchuricht's Avatar
Drivers Side door lock switch.
post #5 of 15 Old 09-22-2010, 07:52 PM Thread Starter
i will try that thanks for your help
post #6 of 15 Old 09-22-2010, 08:03 PM
Shade tree mechanic
95dieselsmoke's Avatar
Yeah, sounds like a faulty switch, let us know if cleaning the contacts help.
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #7 of 15 Old 09-22-2010, 08:37 PM
wingnuts514's Avatar
you can order a switch off ebay for about 1/2 dealer price
wingnuts514 is offline
post #8 of 15 Old 09-23-2010, 02:57 AM
precisionpowercleaning's Avatar
I had that exact same problem when I got my truck. Mine was a cut wire under the dash near the base of the steering column. Can remember for sure what color the wire was, Ill check when the sun comes up. It was one of the door switch wires.
Cory
99 F250 Super Duty Crew Cab 7.3 Powerstroke
precisionpowercleaning is offline
post #9 of 15 Old 09-27-2010, 07:07 PM
As others have said, clean the contacts, contact cleaner would be a good choise as well.
immortalic is offline
post #10 of 15 Old 09-27-2010, 07:22 PM
JSchuricht's Avatar
Yep, contact cleaner and carb cleaner work well too. An old toothbrush will also help, jut be gentle.
