Do I have a limited slip differential? - Ford Powerstroke Diesel Forum
Old 09-22-2010, 04:44 PM
Are there any vin codes or tags that would tell me if I have a limited slip differential? I could just go out and pour the coals to her but she has some miles and don't want to tear anything up. She's a late 99 f250 7.3 2WD
Thanks
Cory
Old 09-22-2010, 04:54 PM
Yea there is a tag on the right side of the diff. On the first line there are some numbers . mine says , 4.10 F81A AUG . On the second line are some other numbers and finally 2 letters ....... LS . This means it is a limited slip .
That being said mine is a Dana 80 , yours is probably a Sterling with a 10.5 ring gear .
Last edited by Bad Night; 09-22-2010 at 05:07 PM. Reason: forgot to put the gear size
Old 09-22-2010, 04:56 PM
ADMIN AND TECH
on the tag on the rear end , it give gear ratio like 3.73 if you have a limited slip, it says 3 L 73
Old 09-22-2010, 05:09 PM
Hey Scuffy is that how the sterlings let you know ?
Old 09-22-2010, 05:10 PM
ADMIN AND TECH
yep
Old 09-22-2010, 05:14 PM
Cool , wasn't sure on those .
Old 09-22-2010, 05:27 PM
Sweet, thanks guys I'll check it in the morning!!
Thanks again!!
Old 09-22-2010, 06:06 PM
Easier way... Check the white tag on the driver's door jam. It'll probably say C1, which is 3.73 LS, although I just ran out to the garage to double check my truck, and it doesn't list anything on that sticker.
It might have it on the axle tag, but sometimes whoever serviced the diff last doesn't put the tags back on.
Old 09-22-2010, 06:18 PM
Everyone is right. Door jamb says c1 and tag says 3 L 73. I guess it's safe to say I have a 3.73 limited slip thanks everyone
Old 09-24-2010, 12:02 PM
pup pup is offline
Does it work to jack up both back wheels and spin one by hand, if the other wheel turns the other way=open diff, if they both spin the same way=limited slip?
