Does the AIH delete make a difference? - Ford Powerstroke Diesel Forum
Old 09-22-2010, 02:28 AM
Hey guy
I was wondering if AIH delete makes a difference or not. I know it’s easy to do but is it worth the trouble?
Thanks
Old 09-22-2010, 03:09 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
I didnt notice a difference but I think it was worth it. Smoother airflow into the engine
Old 09-22-2010, 12:22 PM
I did it to get a place for my boost fitting...
Old 09-23-2010, 10:24 AM
I turned mine into a boost fitting. It's a good location for your boost gauge.
Old 09-23-2010, 06:17 PM
dmd dmd is offline
If you are conservative, you will see a slight increase in milage. Towing you will
have better throttle response. Easy and cheap is to just get a Dodge oil drain plug, it
is the exact size you need.
Old 09-23-2010, 07:55 PM
from a cummins?
Old 09-27-2010, 05:58 AM
ok thanks guy . hear your get only soft codes from doing this also? no biggy i guess?
Old 09-27-2010, 08:08 AM
plugged mine with a chevy oil drain plug last night. ha. truck seems to be happy. every little thing helps. i'll put it back for emissions bs but no big deal.
Old 09-27-2010, 11:26 AM
No change here.
Old 09-27-2010, 11:39 AM
i did mine, little bit of responce that is better but i do get the air intake heater circut low code. i took out the aih and it is huge i thought it would be a good idea to take it out. so i have a afe or somthing one.
