have a wierd boost noise,not sure were to start - Ford Powerstroke Diesel Forum
Old 09-21-2010, 10:53 AM
since i have installed the intake ive noticed that under partial throttle i get what sounds like backed up boost pressure. from what i have read it seems it comes from the boost control valve in the pedestal. if im under full throttle and let off just a little you can really hear it. what causes this? is it bad? how can i fix? im planning on installing a ww,non-ebv pedestal and porting the turbo were i can.
Old 09-21-2010, 11:07 AM
more reading shows that it may be the turbo solenoid. are failures common for these?
heres a video i found that sounds just like what im hearing,
Old 09-21-2010, 11:16 AM
That sounds like your intake just tryin to keep up with your turbo to me. What intake did you install?
Old 09-21-2010, 11:18 AM
the DIY with 6637 and 4" tube. nothing fancy.
Old 09-22-2010, 08:59 AM
If it sounds like that, it's turbo surge & a wicked wheel took care of it for me.
Old 09-22-2010, 05:14 PM
yes wicked wheel will take care of it
will sound better too
Old 09-27-2010, 07:08 PM
Boost surge for sure, wicked wheel will solve it. Short intakes don't work well with some turbo's.
Old 09-27-2010, 07:18 PM
yep thats what mine sounded like
wicked wheel cured mine
Old 09-27-2010, 09:51 PM
got an appt to have one installed on thur. id do it myself but rotator cuff surgery has me gimped up.
Old 10-03-2010, 07:12 PM
so today i noticed the noise alot. ive heard surge before and this has me stumped. the boost gauge jumps around alot right around 20psi.if i back off and get into it again i can make it go away. if it is surge its BAD.
