need some input 2000 7.3 project
I am combining a matching pair of 2000 ex cab long box trucks. both have been wrecked I am going to come out with one good truck frame and cab but my questions are about my engine/ trany options
Truck 1 7.3 auto, was rolled currently runs and drives, smoke due to oil in intake from rollover Truck 2 7.3 zf6, front end collision bent frame ruined everything in front of engine. even broke water pump, I did jump start for 1 second just to be sure it would fire off. the truck I am planing to end up with will use the zf6 trany that I will have to swap over to the good frame. my question is should I swap the engine and trany together or just tranny, cabs are already off, second what is my best option for selling the unused motor. I am thinking that selling the running engine with auto tranny together would bring more. and I would have to fix up the one with broken water pump or I could buy 2000 Ford F-250 XLT SD and insert my tranny/transfer, buy the rest and sell truck ![]() what do you think? |
I am not an expert so please excuse me if this a dumb statement but i would check to make sure the transmissions are interchangeable, i know there are a few different versions of the 7.3 motor, but im not sure if that affects the transmission. Second i would do a through check on the actual damage to both motors. Anytime there is a crash there is always the possibility for non-visible damage. As far as what would be the best motor to sell depends on the damage. Obviously the least damaged motor would fetch a higher price. Although if you keep the motor with the most damage then you will incur more costs in repair. Unfortunately without knowing the true extent of the damages its hard to say which motor is better to keep or sell. On a personal note i would be leery about buying any wrecked motor and would expect it to be sold way under what the motor was actually worth. This might make it a wash no matter what motor you sell. I hope this helped.
