Changed Battery Cable and now Battery Light ON. Help... - Ford Powerstroke Diesel Forum
Old 09-18-2010, 09:06 AM
I replaced my positive battery cable on my truck today and when I was done I started truck and the battery light is on. Why is the battery light on? What causes that light to come on? I am sure everything is hooked up right. It runs ok and starts ok but the battery light is on. Can anyone help please?
Old 09-18-2010, 09:11 AM
Pop the alternator off and get it tested. That can cause it too.
Old 09-18-2010, 09:12 AM
Its actually a newer alternator I put on a few weeks ago and light didnt come on till after I changed cable.
Old 09-18-2010, 09:15 AM
ohhh. Hm. Is everything tight tight tight? on both batts. I know it sounds a little ... newbish but once mine flipped out cause they were corroded and not as tight as possible, batt light came on, then gauges went haywire. it was weird. But even your belts, and that tensioner, make sure all that's good too.
Old 09-18-2010, 09:20 AM
Ya everything is good and tight. I checked over it twice. I just cant seem to figure it out.
Old 09-18-2010, 08:51 PM
Got it fixed. Thanks.
Old 09-19-2010, 06:30 AM
What caused the problem?
Old 09-19-2010, 12:37 PM
It was actually just one of the wires on the starter solenoid had fallen off when I disconnected it and I didnt see it. I think it was the wire that went to the alternator. Hooked it up and all is good now.
