Old 06-08-2007, 03:48 PM
brick58 brick58 is offline
I have an oil leak on top of my 01 7.3. It looks like a brass bolt or maybe some kind of plug under the fuel filter...I found part of an o-ring and it feels like there should be an o-ring on the plug...Can someone tell me what this brass plug is????? please help???????
Old 06-08-2007, 03:54 PM
Oil Leak Under Fuel Filter (help!!!!)
I have suddenly developed an oil leak under the fuel filter. It looks like a brass plug or brass bolt head. There is a lot of oil in the valley between the heads and after the engine gets warm and you bring the rpm's up it starts to leak around this "plug??" I found part of an oring in the valley and it feels like there should be on around the brass head...Can someone please tell me what this is before I remove it?????
Old 06-08-2007, 09:08 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
Bump for ya!
Old 06-08-2007, 09:20 PM
WEWILLE WEWILLE is offline
ready for spring
I dont know what it is maybe if you could get a picture then it would be easier to tell. But i am sure that somebody around here knows what it is
Old 06-09-2007, 09:15 PM
straycat straycat is offline
Get a new O ring on it for now, and get the oil leak stoped, Call ford and get the parts guy to check his blowups for the part and name, hope that helps man.
Gord.
Old 06-09-2007, 09:24 PM
I merged your two threads into one for you, you will still get the info you need, but take up less space.
Gord.
