03 7.3 trans safety switch can i bypass? - Ford Powerstroke Diesel Forum
Old 09-17-2010, 12:00 PM
My 03 7.3 has the safety switch that when you stomp on the pedal it kills the throttle so that it wont hurt the trans. I i about got hit cuse i forgot about it, what stupid @$$ idea that it. Is the only way to get rid of it through a tuner or can i do something myself. thanks vince
Old 09-17-2010, 09:56 PM
Are you sure? I havent heard of this before, does it trow a code when the engine cuts out.
Old 09-17-2010, 10:00 PM
riddin' high
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
hmmmmmmmmm. if anything, a chip/programmer/CUSTOM TUNES will get rid of that for you, while still being safe.
Old 09-21-2010, 07:31 PM
Yes and your truck might even do it as well, i know that the 6.0s do it. i was trying to catch up to my friend and i smashed the pedal hard to the floor and then lost throttle response for about 2 seconds then it returned and the trans light came on during that time. to verify i did it again and everytime afterwards. its a safety so that you do not hurt the trans, i know someoe with a 6.0 that it does the same thing. my 7.3 is an 03 and has the wiring of 03-07 even my fuse box differes from that of a 99-02 7.3. im sure when i get my dp tuner that will bypass all that.
Old 09-21-2010, 07:41 PM
.......my truck doesn't do that. And i don't have a tuner....
Old 09-22-2010, 08:22 AM
Yea that's not normal. If the OD light comes on during that you got a problem.
Old 09-23-2010, 12:24 PM
+1, my 03 with a 7.3 and an auto doesnt do it on stock tuning. My brother in law has an 05 6.0 that doesn't do that on stock tuning. I think you have other problems. I dont know what they might be... but...
Old 09-27-2010, 10:52 AM
TRANS SAFTEY SWITCH
WELL IT SEEMS THAT IT WAS PROGRAMMED THAT WAY IT DOES IT EVERY TIME. I WOULDNT DOUBT THAT IT CAME FROM THE FACTORY THAT WAY.I HIT THE PEDAL HARD, U ACTUALLY HAVE TO APPLY SOME GOOD FORCE TO IT NOT JUST PUSH.I MEAN SMASH THE HELL OUT OF IT HAHA. IM NOT SAYING THAT IT DOESNT WORK FOR U I JUST SEEMS TO BE NORMAL ITS NOT INTERMITTENT OR ANYTHING.
Old 09-27-2010, 11:13 AM
sounds like you have an issue with your pedal sensor or what ever you call that. someone else will know what its called. I think there was even a tsb on it at one time
Old 09-27-2010, 11:16 AM
Ive never heard of anything like that. Id like to see what comes of this thread
