  #11 (permalink)
Old 06-08-2007, 02:38 PM
slammedSI slammedSI is offline
Originally Posted by MrJohnWayne View Post
I'm thinking I should be well over 300 hp at the wheels. I think my hpop is weak but I don't want to pay ford the 100 bucks to test it. I'm ordering my stealth hpop system so I won't worry to much about it. We'll see what it does once I get the stealth installed.
Whens that gunna be.
  #12 (permalink)
Old 06-08-2007, 02:49 PM
Lord Tauk Lord Tauk is offline
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
I remember talking to Jody about his 120 tune before I ordered my DP chip, he mentioned to me the condition of the HPOP will depend on the amount of smoke.. I think a strong stock HPOP will put out a lot of smoke then clear up when you mash it because it's supplying the injectors with more oil pressure than a weak pump that wouldn't put out much smoke - I think that's correct in how he said it.
  #13 (permalink)
Old 06-08-2007, 03:40 PM
Logan Logan is offline
The Fat Mod
Looks good JW. I would still think you would be higher as well. Course, I don't see any corrections there, so not sure how it was run. Usually the corrections will put ya higher. Still dont know alot about dyno's though.
  #14 (permalink)
Old 06-08-2007, 08:15 PM
jngreen jngreen is offline
Send a message via AIM to jngreen
I agree with everyone else, you should be higher with your mods......
  #15 (permalink)
Old 06-08-2007, 09:17 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
I know if i'm in 3rd (6speed) running abour 20 mph and mash it it will smoke its arse off but clear up when the rpm's rise.
I'm still not sure on the dynos either
That's what I think too! I guess i'm gonna have to bite the bullet and take it to ford.........
  #16 (permalink)
Old 06-08-2007, 09:27 PM
after it gets here.
  #17 (permalink)
Old 06-08-2007, 10:11 PM
Stroked95 Stroked95 is offline
Did you pull the outside tires off this time when you dynoed?
  #18 (permalink)
Old 06-09-2007, 07:33 AM
like I said before, you can and prolly should test the hpop pressure before you install your stealth system..... (and after)
you can use a mechanical guage that you temporarily mount through your hood and hold it down with you windshield wiper or hold it in your hand if you are sure its not gonna leak......
or you can also read it with a good diagnostic scanner while you drive down the road......
  #19 (permalink)
Old 06-09-2007, 07:37 AM
the outside wheel and tire should not rob that much, think about guys with similar mods and 37 in tires or bigger that are puttin down better numbers.....
I had 39.5in tires on my truck, and they aren't light.
  #20 (permalink)
Old 06-09-2007, 07:45 AM
It will still read higher HP minus the outside tires. The outside tires probably didn't even rub but it's a lot of excess wieght that a similarly equiped SRW truck wouldn't have. Think about the guys with similar mods and 37in tires if they went back to stock tires on the dyno they would pick up a few HP. Just something to consider, I still think for the mods it's a little low on the HP.
