Audible high RPM warning? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 09-15-2010, 06:11 PM Thread Starter
tristanlee85's Avatar
Send a message via AIM to tristanlee85 Send a message via MSN to tristanlee85 Send a message via Yahoo to tristanlee85
Loud humming at higher RPM under load
I've did a good amount of searching, but with no results or with the wrong keywords. My 7.3 has about 192k on it and I've noticed when I rev to about 2200rpms, there is a noise that reminds me of the sound a rotary engine makes as the RPMs get real high. It's not really high pitched, but definitely noticable. I figured maybe the engine has a similar warning system, but I think 2200 is a bit low for such warning, though I could be wrong as this is the first diesel engine I've messed with.
Does such thing exist and if not, I wonder what could be making the noise. I'm lost at where to begin really.
Tristan
1999 F-250 SD
tristanlee85 is offline
post #2 of 20 Old 09-15-2010, 06:17 PM
Zaairman's Avatar
Quoted: 12 Post(s)
2200 RPMs is not high. Are you sure you're not just hearing the turbo spool up??
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 20 Old 09-15-2010, 06:18 PM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
well it is not suppose to happen. But these are noisy motors so it might be normal. Get someone to listen to it that knows about these motors.
They will let you know.
2002 f250 BFT Edition
dereku is offline
post #4 of 20 Old 09-15-2010, 06:24 PM Thread Starter
It's definitely not the turbo spooling up, though part of that did cross my mind as possibly the bearings being bad or the shaft being out of balance. I've had a turbo where the impeller would ride against the compressor housing as it spooled, but it didn't sound like this.
Tristan
1999 F-250 SD
post #5 of 20 Old 09-15-2010, 09:32 PM Thread Starter
Seems to be related to the load and not RPM. I'm still not too comfortable with the truck's limits so I have not been pushing it hard at all except tonight I wanted to figure out exactly where the noise is coming from. It seems like I get it to make the noise when in 4th around the 2200 - 2400 range under WOT. It seems to be coming more from the transmission area rather than up front with the engine. The first thing that comes to mind is the clutch slipping or at least trying to though all clutch slippage I've felt before on an ACT 6-puck disc made no noise. The RPMs just quickly rose.
I am assuming the disc is a solid disc and not a puck style. I can't really think of anything else at this time that could make such a noise. I wish I could capture good audio of it.
Tristan
1999 F-250 SD
post #6 of 20 Old 09-24-2010, 04:46 PM Thread Starter
Bringing this back... probably could use a different thread title. Here is a video I took today with my phone. Audio is more important than the video anyway. Around 2600rpms is when the loud hum or whatever that is starts. I feel no change in the RPM, speed, or anything else. I sounds like it's coming from either the front part of the transmission/rear of the engine, but it's hard to tell. I can't think of what it could be.
Tristan
1999 F-250 SD
post #7 of 20 Old 09-24-2010, 06:40 PM
Lifetime Premium Member
jbeasts10's Avatar
I have never heard that sound before in mine.Heres a bump for ya...
2001 F250.Custom Tuned,Ball-Buster Turbo,5"Exhaust
ITP Reg.Return,TD Billet Converter,Built Tranny,Snow Meth/Water Stage 2..plus a few more things!!She will Hunt
jbeasts10 is offline
post #8 of 20 Old 09-24-2010, 06:54 PM
At that rpm and under wot that is probably making max boost you wouldn't have a rubber boot on the turbo pipes leaking would you that doesn't sound like a mechanical noice more like a wierd whistiling noise to me.
2001 F-250 7.3L
6-speed manual trans.
D.I.Y. Intake
3.5" straight pipe exhaust
Future Mods
HPX hose
Fuel crossover kit
IBEW Local 343 member
01clj is offline
post #9 of 20 Old 09-24-2010, 07:06 PM Thread Starter
It's possible... I'm not ruling it out. I don't have a boost gauge and I'm not sure what it should be making right now, but I would think before 2600 I'd be at max pressure and that it would happen then too. It's also pretty immediate. I would think as pressure built the noise would gradually get louder.
Tristan
1999 F-250 SD
post #10 of 20 Old 09-25-2010, 06:38 AM
Zaairman's Avatar
Quoted: 12 Post(s)
Uh...wtf.
Zach
SLAPS Member #153
Zaairman is offline
