Tire Size Question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-10-2010, 05:58 PM Thread Starter
ZachBoyer's Avatar
Tire Size Question
I looked around alittle for the Max tires size that you can use on a stock height 2002 F250 4x4 Crew Cab Short Bed and couldnt find much.
Right now Im running 285/75/16 slicks and I am in need of some tread.
I would like to go alittle bit bigger.
I found some 315/75/16 tires
Would they fit without rubbing etc?
Tire Dimensions Made Simple - Discount Tire
The Tire Calculator said they were 1.77 inches bigger overall diameter..
Thanks!
2005 F250 6.0 King Ranch Crew Cab Short Bed 4X4
-MODS-
4" Turbo Back Straight Pipe
Sinister EGR Delete
Sinister Coolant Filter
Cat EC-1 Coolant
ZachBoyer is offline
post #2 of 7 Old 09-10-2010, 06:12 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
I also am in need of new skins. Right now I have 305/70/16 Nitto Terra Grapplers on my 2000 F250 crew cab , long bed . I have a 2.5" leveling kit on it and these tires rub a little at full lock and just touch the inner fender well when turned to full lock. I'm looking at going to a 285/75/16 to stop the rub , although its only minor rubbing. Our winters up here, we see a lot of snow , so a narrower tire is needed. I can't see how you could go to a wider or taller tire with a stock height. I had to put the leveling kit on just so I could put on mud flaps,
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 7 Old 09-10-2010, 06:15 PM Thread Starter
ZachBoyer's Avatar
Maybe my tires are so bald i dont remember them being 'filling'
According to the website i listed above. your 305s are .2 inches smaller but that tire is almost 1 inch wider than a 285
So I guess thats the limit
-MODS-
Sinister EGR Delete
Cat EC-1 Coolant
post #4 of 7 Old 09-10-2010, 06:21 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
The width is what causes the rubbing, so I might be able to go an inch taller. I'd have to measure to be sure , I wouldn't want to spend almost $ 1000 and find out they are to big. I know I'm safe with the 285/75/16, but I'll have get a better look tomorrow.
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
Isspro 3 Gauge Pod
Banks Big Head
298K
post #5 of 7 Old 09-10-2010, 06:51 PM
Lifetime Premium Member
jbeasts10's Avatar
I have the exact same tires and size as Greasy.I am leveled also.Mine doesnt rub at full lock.I am not positive that a 315 would clear though.IMO.
2001 F250.Custom Tuned,Ball-Buster Turbo,5"Exhaust
ITP Reg.Return,TD Billet Converter,Built Tranny,Snow Meth/Water Stage 2..plus a few more things!!She will Hunt
jbeasts10 is offline
post #6 of 7 Old 09-11-2010, 03:40 PM Thread Starter
ZachBoyer's Avatar
I broke down and just got some 285 75 16's again. My next tire purchase will be for some bigger rims from a 03-06
-MODS-
Sinister EGR Delete
Cat EC-1 Coolant
post #7 of 7 Old 09-12-2010, 05:46 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
What tires did you buy and why? I'm ordering new skins tomorrow, the Nitto Terra Grapplers 285/75/16 load range E are on national backorder for 3-4 weeks. Now I need to make a decision as to what i can get . I need them within the next 2 weeks, so I can't wait on the nittos.
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
Isspro 3 Gauge Pod
Banks Big Head
298K
