CCV.. Why cant I just plug it? - Ford Powerstroke Diesel Forum
Old 09-10-2010, 01:02 PM
Any thoughts?
Old 09-10-2010, 01:29 PM
because the crank case gasses will be trapped in your motor and can explode...
Old 09-10-2010, 03:24 PM
It's all about pressure.....
Because of the high compression ratio, more blow-by gasses get past the rings. If not vented, the pressure would build and force through all the seals it could, causing Massive oil leaks!
Old 09-10-2010, 05:51 PM
ah ok, thanks
