oversize tire question - Ford Powerstroke Diesel Forum
Old 09-09-2010, 11:02 AM
im new to oversize tires. the truck i bought has 37x13.50 toyo open countries on it and they're practically new. today i noticed a slice/split across the trad pattern. it goes through one of the lugs and between the tread. I'm wondering what caused this. Are bigger tires known to split like that? or does anyone have any insight as to what may have caused this
Old 09-09-2010, 11:23 AM
does it go all the way across? It could be the seam where the the tread comes together
Old 09-09-2010, 11:36 AM
could just be a cut or maybe dry rot, check the date code on the side.
Old 09-09-2010, 01:34 PM
its not dry rot, and it s uneven so its not a seam. i was just wondering if this is comman with larger tires
Old 09-09-2010, 02:00 PM
I have 37x13.5x20 kumhos on mine and I dont have anything like that wrong with mine, I would suggest taking them back to where they were bought and see if they will waranty it
Old 09-09-2010, 02:26 PM
Post a picture of it so we can get a better idea of what your talking about?
Old 09-09-2010, 02:59 PM
Chapter Director
i had that happen on my last set of tires they were 15in wide tires on a 9 in rim according to the tire shop thats what caused it and wouldnt replace it, well now my new set of toyos is starting to do this again, but they are on the proper sized rim so they will be hearing from me if this continues to get worse.
if its just in the lugs i wouldnt be to worried about it but as soon as it goes into the main part of the tire you got a major problem. so keep an eye on it. mine went within 1000mi
Old 09-09-2010, 06:54 PM
I wouldn't drive on those much longer, could be serious. The basic answer to yur actual question is no they shouldn't have this problem
