removing pyro from manifold, what to use to plug the hole? - Ford Powerstroke Diesel Forum
Old 09-09-2010, 09:25 AM
G1K G1K is offline
I'm getting ready to trade in my 2002 on a newer truck. I am going to switch all the pillar mounted gages over to the new one. The only problem I am expecting is the pryo. I drilled and tapped a hole in the drivers side exhaust manifold. When I remove the pyro, what sould I use to plug up the hole?
Ryan
Old 09-09-2010, 09:52 AM
Find a bolt of same thread as the sender and put it in there. If the sender has been there without any problem, why not a bolt?
Old 09-09-2010, 10:08 AM
Send a message via AIM to troid123
Ryan
Go to your local hardware store. I.E. LOWES, HOME DEPOT, ETC... And buy a plug or small bolt with the same size & thread pitch as your pyro had and stick it in there...
Old 09-09-2010, 10:20 AM
Unapologetically American
Feedback Score: 4 reviews
Yeah, leave the fitting in the manifold, and just go get a new brass plug. I doubt you'll get that fitting out of the manifold, and could cause damage. You should be able to get a new fitting from the same parts house as the brass plug
Old 09-09-2010, 10:26 AM
leave it in there, and buy a new probe
Old 09-09-2010, 10:44 AM
i went to the hardware store and got a 1/4 inch npt pipe plug. thats whats in mine now
Old 09-15-2010, 06:23 PM
G1K G1K is offline
I found a non-brass 1/4 NPT plug at the local hardware store (not HD, LOWES etc. They only had brass).
2002 F-250 is gone and the '06 Dually is home.
Thanks for the help guys...
R
Old 09-15-2010, 06:59 PM
my obs when i sold it, i just stuck a bolt in it.
