HELP ! will upgrading the oil system make low cylender last longer ?
one cylender is low due to air filter problem. Will upgrading the oil system prolong this cylender, its like 30lbs above the minimum level?
is it worth it or do i need to park the truck.? |
Im not sure to your answer id run her til she blows. but heres a friendly
for ya
How did a cylinder go bad due to an air filter?
And what kind of upgrades do you mean? Higher pressures or what |
I'm not sure, but I feel for ya.. My truck needs some money put into it and the house fixing up is taking all my cash!
Good luck |
Did you do a leak down test?
Leak down of cylinder pressure or injector HPO? Cause there isn't a HPF rail to leak down. JW cause when most ppl say leak down they are referring to HPF
Of cylinder pressure to see where the loss of compression is happening. What is HPF stand for?
High Pressure Fuel
