Wheel Bearing Question - Ford Powerstroke Diesel Forum
Old 08-30-2010, 04:08 PM
I bought my 99 super cab 4x4 just over a year ago, the guy i bought it from replaced the factory hubs with waren manual lock outs. my question is with this being done, does this mean i have a standard wheel bearing setup, spindle inner outter bearings, or do i have the hub bearing oe style? i have read about people doing the waren conversion and that eliminates the hub bearing and goes back to an old school spindle style set up. but im not sure if that is a seperate conversion or if its accross the board. thanks for any input.
Old 08-30-2010, 04:19 PM
i would assume its just the warn lock outs. I bet the hub is factory.
Just FYI, if you have an early 99 the wheel bearings are expensive to replace.Just get late 99 thru 02 hubs and get brake rotors for the same late 99 thru 02.Hub and rotor is cheaper by a lot then the early hub alone. Its ok to do one side only. Just remember what you did.
Almostdunfukinwidit
You have the oe style hub
Old 08-30-2010, 04:40 PM
ok thanks for the bad news! only good thing is i have a mid-late 99
Old 08-30-2010, 04:42 PM
Yup, you have the expensive ones.
Old 08-30-2010, 06:14 PM
mid to late 99 are the cheaper ones. Early 99 is a lot more cash.
Old 08-30-2010, 07:46 PM
$250 still isn't cheap to me
Old 08-31-2010, 02:15 AM
i bought mine offf ebay 120 shipped each one. Its a good bearing too. Look thru ebay. If you cant find one that you like i can find my paper work and give you his ebay name. Hes in nc I think moorsville. Guaranteed for life too, But shipping it back would be a pain.
but still cheaper then new ones.
Old 08-31-2010, 04:01 AM
The first thing you need to do is find out what your truck's production date is, that will determine whether you have the old style or new style.
If you have the old style (I believe on trucks built to 3/21/99) those are more expensive, BUT, you CAN CONVERT to the new style.
Personally, if you haven't done rotors yet, I'd recommend converting to the new style by replacing your hub assembly and rotor on both sides with the newer style ones. It'll be about the same price as buying 2 new hub assemblies for the old style.
