Newbie Questions - Ford Powerstroke Diesel Forum
Old 08-28-2010, 05:50 PM
Newbie Questions
Hello all. I am pretty good with engines but I am a newbie when it comes to both diesels and the forum. I just bought a 2000 xlt 4x4 supercab shortbed. It runs well and seems to be in good overall condition. It does have a mod that i am not sure about and was hoping someone could shed some light.
On the dash between the stearing column and the 4x4 shift knob there is another knob. It has 6 or so settings, 3 of which seem to do nothing except 1 wont let the truck go over 65 mph, and the other 3 at idle will bump the idle up from 700-800rpm to 1500rpm just sitting. I havent really tested all the settings at different speeds etc for fear of damaging something.
I have not been able to locate any brand or name on the knob and have not yet been able to tear into the dash looking. Any ideas of what this might be would help me a great deal. I do not want to damage anything by running on the incorrect setting.
Is there certain information from certain places on the truck that might be good for me to have in asking questions on the forum (Tranny, etc). Thanks
Josh
Old 08-28-2010, 05:55 PM
drives a ranger
Send a message via AIM to kanuck15
That is a tuning chip. the one setting that wont let it go over 65 is valet mode. the other one is a high idle setting. good for warming up or keeping AC cold. the rest are horsepower setting. you will notice a difference while driving with those. they are usually 50-75-100-140hp settings
Old 08-28-2010, 06:33 PM
Thanks for your reply. I thought it was some sort of tuner. Going from 12 o clock, clock wise the first setting (12oclock)= High RPM, 2nd setting= Valet mode (wont go over 65), 3rd setting= regular idle/operation (more kick than stock), 4th setting= regular idle/operation (little time here), 5th setting= increased idle (havent driven it here), 6th=increased idle (havent driven it).
If those 5th and 6th settings are just increase HP should they have the increase idle?
Is there other things that usually accompany tuners that I should check for? I will be using this truck to tow 5th wheel motorhome type trailers. thanks again
Old 08-28-2010, 06:38 PM
Raising the idle may make them quicker i know mine bumps about 500 in my 140 setting. I might add that if you don't have gauges I DONT recommend using any of the hot tunes as you can melt something and have a mess on your hands oh and :welcome:
Old 08-28-2010, 06:54 PM
Thanks Glad to be a Powerstroke owner! I dont plan on using the hot settings. And the gauges you are talking would be boost and ? Also does this kind of tuning give MPG benefits or hurt MPG? What should i look for under the dash to identify the specific type of chip. thanks
Old 08-28-2010, 06:58 PM
it should be in the PCM under your emergency brake on the left side period make sure the keys are in the house yes in the house if you pull it out. if you need help pulling it out pm. and your gauges would be Pyro to see the exhaust temps Boost and trans if it is an automatic. I would also recommed a DIY tymar go to diyfilters.com and get a 6637 and an exhaust and you will be grinning ear to ear. Also it will help mileage
Old 08-28-2010, 07:34 PM
Thanks for all the info. the truck does have a larger exhaust but i am not sure what exactly it is.
