Fuel Pump and Pick Up Tube - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-27-2010, 12:13 PM Thread Starter
Question Fuel Pump and Pick Up Tube
I have an 01 Excursion with a 7.3. Loosing power like it was starving for fuel once it reached operating temp. Dealer says I need fuel pump and drop tank to clean and/or replace pick up tube. Does anyone know if an aftermarket fuel pump will work just as well and just as long as the dealer part?
GotOne2 is offline
post #2 of 7 Old 08-27-2010, 01:51 PM
ridiculously_necessary's Avatar
should. ebay has some for about $80. they are generic pumps, but i think made by Airtex, by the looks of them. for what a dealer would charge on a pump, i would spend a tad more and get a FASS/AirDog.
the tank has a funky problem with it sometimes, but i dotn recall what, hopefully someone else will chime in...
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #3 of 7 Old 08-27-2010, 02:34 PM Thread Starter
thanks rd for the reply.
GotOne2 is offline
post #4 of 7 Old 08-27-2010, 05:43 PM
99BEIGEPOWERSTROKE's Avatar
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS 175/146 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99BEIGEPOWERSTROKE is offline
post #5 of 7 Old 08-28-2010, 10:32 AM
Before you go buying a fuel pump drop that tank and do the hutch mod, which will cost you less than $20 bucks at any parts house, reinstall and if that wasnt the fix, Then replace fuel pump.
I recently had a full lesson (about $1300) in the fuel system from a scheisty mechanic. We will be more than happy to walk you thru it.
Sold for no reason?!?
2001 F350 SRW CCLB 4wd 252k, Tuned lifted, etc...
Gone but not forgotten, 2 motors(170kand 245k)!
2008 F250 CCSB 6.4 KR 4wd, H&S Powered
Trying out the 6.0! Bought w/135k
Amarillo Package, '06 CCLB SRW F350 4WD Sinister EGR Delete, Sinister Coolant Filter, 4" naked exhaust, ID Tuned, Blue Spring Fuel Update, Updated Ford oil cooler and Dummy Plugs, 35's on 20's, Flares, 3"coil spacers, RK Toolbox, Sunroof
Coalrolla9740 is offline
post #6 of 7 Old 08-28-2010, 06:03 PM Thread Starter
thanks coalrolla
GotOne2 is offline
post #7 of 7 Old 08-28-2010, 07:38 PM
i just went through something similar but my pickup was cracked according to the dealer and aerated the fuel causin #8 inj to crap the bed
'02 Ex cab SB
6637 filter
zoodad
3.5'' magnaflow muffler(freebie!)
diy ccv mod
smoked recons up top
16.82@78 with 2.2k weighing in at 7,035lbs
86 lx notch....more torque than the truck
408w and 101mm-9.27@134 lifting
86lxnotch is offline
