Beans up pipe gaskets - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-25-2010, 01:18 AM Thread Starter
DJM
DJM's Avatar
Well I finally ordered my up pipe gaskets from Beans anyone had good luck with these I would of liked IH pipes but can't afford it right now. I k ow people use the chevy gaskets but these seemed to look a little better.
2001 Crew Cab, Auto
6in lift, 37Toyo's
DP F6 60eco,80tow,80eco,120
Wicked Wheel
Foil Delete
Isspro EV2 Guages
HPX Line
RiffRaff FRx
4" Exhaust
AFE Big Boost
FS 2500 Filter
DJM is offline
post #2 of 5 Old 10-05-2010, 06:23 PM
ricochetbuell's Avatar
how did these work out for you?? i am having trouble with them fitting on my up pipes, they are real tight and think they are hindering everything lining up on the reinstall.
2001 F250 Crew Cab Short Box, 4" Pro Comp Suspension Lift, Banks 4" TB Exhaust with Banks Power Elbow, DIY Intake, Banks Big Head, Upgraded Lights, Monotube Adjustable Shocks, Guages, Toyo M/Ts , CCV Mod, A/C Mod, Foil Delete, AIH Delete, Zoodad, Dinger Delete, Hutched and Harpooned, ISSPRO gauges, PHP Phoenix
ricochetbuell is offline
post #3 of 5 Old 10-05-2010, 10:39 PM Thread Starter
DJM
DJM's Avatar
I havnt had the time to do it yet with work and hunting season goin on I need to get it done though
2001 Crew Cab, Auto
6in lift, 37Toyo's
Wicked Wheel
Foil Delete
Isspro EV2 Guages
HPX Line
RiffRaff FRx
4" Exhaust
AFE Big Boost
FS 2500 Filter
DJM is offline
post #4 of 5 Old 10-07-2010, 07:46 PM
I have another post going with how it worked for me. I have not completed it yet but should be done by Saturday some time. I had to go about it another way then described in various threads and instructions about replacing up pipes and gaskets because the brass donuts fit so tight they wouldn't move on the pipes and made it impossible to reinstall the turbo. Overall not too bad of a job and I hopefully fixed my oil leaks as well. Oh also found out I had the Banks Power Elbow and didn't even have the EBPV. I did go ahead and gut the pedestal because it was leaking.
post #5 of 5 Old 10-08-2010, 05:30 AM Thread Starter
DJM
DJM's Avatar
Yah I have a gutted valve to put on and a non ebpv pedistal to put on also wile I got the turbo off. I have heard of some people heating the brass up and smashing them a bit with a hammer I was just gona heat them up with a torch put them in and hopefully wile it's still hot I can suck it down enough. I was gona mark everything with a paint pen so hopefully Inwont have any line up issues with adjusting the uppipes around.
2001 Crew Cab, Auto
6in lift, 37Toyo's
Wicked Wheel
Foil Delete
Isspro EV2 Guages
HPX Line
RiffRaff FRx
4" Exhaust
AFE Big Boost
FS 2500 Filter
DJM is offline
