Advice please - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-22-2010, 05:32 AM Thread Starter
squirtgun's Avatar
Advice please
This is a video of a truck we would like to buy the current owner says there is something wrong with the motor.I owe a 6.0L so have no clue what sounds normal for a 7.3L will one of you guy watch and listen and see what you think it might be.I know it's a long shot,but I'm not up for buying a truck that needs a motor or rebuild.
I have a feeling it needs injectors.
2003 6.0L F250 4x4 Lariat
Fog Light Mod,High Idle Mod,Zoodad,Hose clamp taligate mod,08 rear bumper,Sinister EGR delete,ELC EC-1 coolant,Edge Juice,MKM(Sinister)coolant filter,HFCM drain plug upgrade,diy FICM repair(steady 48.5v now),DIY CCV mod,Torque Pro,Blue spring upgrade,Aluminum radiator,05 headlights,LED foglightd
Wish List/Things to do
Y-pipe,fuel pressure gauge,diy oil bypass(maybe centrifuge),oil pressure gauge
squirtgun is offline
post #2 of 4 Old 08-22-2010, 10:58 AM
sounds like a typical 7.3 not running some kinda fuel additive to the pos ULSD crap. Started a little hard IMO. the white smoke is ok if it clears when it warms up but if thats constant theres an issue... honestly you need to get more info then 'there's something wrong with the engine" thats not gonna do any good. could be alotta things.. could be nothing i dunno!
Dietoremain is offline
post #3 of 4 Old 08-22-2010, 11:06 AM
jlarsen's Avatar
sounds normal to me. If it was me I would let it warm up and take it for a spin. see if it still smokes. check for codes do a buzz test and contribution test. how many miles?
2002 F350 Crew cab Lariat
Power Hungry Performance Gryphon- Custom Tunes
GTP38R
Bellowed Up pipes
NON-EBP Pedistal
4 Inch Lift and 35 inch Goodyear DuraTracs
AFE Stage 2 Pro Guard 7
MBRP 4 inch turbo back
GDS High flow power outlet
Zoodad mod
Tranny cooler
Trans go shift kit
Airlift Bags with compressor
1996 extended cab 4x4 Powerstroke TOTALED
5 speed, heavy duty clutch
AFE stage 2 intake pro guard 7 filter
4 inch Diamond Eye turbo back exhaust
cat delete
TW chip
jlarsen is offline
post #4 of 4 Old 08-22-2010, 11:07 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Doesn't sound bad. Pull the fuel filter and check it. Might pour some ATF or something in the fuel bowl then start it up. That'll clear out the injectors.
Was someone banging on metal in the vid? Sounded bad if it was the engine
4R100, 2wd
330,000 + miles
jesilvas is offline
