Commpression test numbers hurt my feelings!
well, found this sitting under the valve cover next to the low (295psi) number 4 cylinder. Any ideas of what monster I have going on here? Numbers on driver side were 370, 295, 390, 355.
![]() ![]() ![]() ![]() I looked best I could with a flashlight and couldn't see anywhere this piece could have come from. |
what ever it is thats not good
oh , and truck runs fine and strong as I can tell just smokes
looks like one of the washer things(dont know what they are called) from the top of a valve spring
![]() ![]() check the valve spring retainers, one of them might be missing a chunk. which could allow the spring to kick over a little extra, and allow the valve to leak? giving a lower compression, unlikely but possible |
hmmmmmmm, anyone have a pic of where it goes.. I have never done any engine work what so ever and not really sure where to look. Also, how do you go about fixing this to see if compression gets better?
Looks like a valve spring shim to me. VS retainers are like a half moon wedge type of thing. It definitly isn't one of them not to mention you would have dropped a valve.
A shim on the other hand would give you less seat pressure and thus lower compression. |
the valve spring retainers are fairly thick,doubt its that.my truck had broke rings,im not sayin thats a ring,but if your smokin,got low compression,then you deff got sumthin going on there..did you run contribution??? get you a cherry picker and pull the heads..i did mine.thinkin it was a valve,and thinkin i would get away with just reworkin the heads,not a chance.pulled the heads and piston was all chewed up from a peice of ring.
![]() Also, anyone have a diagram of where this shim would be in the head, looked all over but don't really know where I need to look either. |
