Coolant plug in block
Does anyone know what that plug is called offically? Its the one with the ratchet head just to the right of the oil cooler. Mine has corroded out and leaked the coolant. I called Ford/Inernational and they dont see the part in their system. What about a part number? Or what about the thread size/type incase I can find a bolt to shove in there...
4th pic down if you like a visual... Ford Super Duty Coolant Flushing Procedure | Superdutypsd.com |
Its called a freeze plug
i thought the freeze plugs were the large unthreaded ones?
I wouldn't use a bolt as the threads on this pipe plug should be a tapered pipe thread. You can replace this plug at a plumbing store. Should be a common part.
thanks, ill check there! this does resemble pipe more than anything else.
