Coolant Change - Ford Powerstroke Diesel Forum
Old 08-18-2010, 11:20 AM
Coolant Change
I need to change my coolant. What is the best way to go about it?
Should I just take it some where and have them do a flush or is there a trick to flushing it your self?
How would yall do it?
Thanks in advance
Old 08-18-2010, 01:55 PM
I'd use the SEARCH function and read some of the thousands of posts on this
Old 08-18-2010, 03:36 PM
Well Im searching now. Not finding alot on the actual how to get the old coolant out but more about what kind, color and addtives etc to put back.
I keep seeing "PET-****" on the instructions to drain it??? What the heck is that?
"Drain radiator at pet-**** ", what is pet-****?
Old 08-18-2010, 04:01 PM
You Know,,, you're Right!
Not as easy a Search as I thought it would be
Try these;
Changing the coolant
Is my coolant Green or Yellow....?
Coolant type???
Old 08-18-2010, 05:21 PM
Try these;
Coolant type???
Thanks man. I found the procedure in one of those.
Its the same procedure I saw earlier but they keep saying "pet-****" instead of drain valve. I dont understand why you would say "pet-****" instead of drain valve.
Old 08-18-2010, 07:03 PM
Cause the thing that you refer to as a drain valve is called a pet****.
Same reason you don't call your tires "round black rolley things"
Old 08-18-2010, 08:43 PM
I know the bad word filters are there to protect someone, but come on mods, can we loosen it up enough to only filter f bombs and maybe the C word? I'm pretty sure 99.9% of us are old enough to vote, and the few that are not are already a step ahead of the rest of their age group as far as maturity because there here, reading about Diesels!
Old 08-18-2010, 08:53 PM
I used to go on a forum which censored the CHIT out of Wichita. I thought that was a little hypersensitive.
Old 08-19-2010, 07:51 AM
Well I must be an idiot cause none of the words or 4 letters I can think of make any sense.
Old 08-19-2010, 08:07 AM
Think 4 letters and another word for that thing between your legs well that's assuming you are a dude and not a girl jay always says silent bob love the word haha
