Quick ? Oil too low just under crosshatch? - Ford Powerstroke Diesel Forum
Old 08-15-2010, 02:09 PM
I just changed my oil and its right under the crosshatch about 15 min after start up. Can I make it to the part store to get a quart more without issues? thanks.
Old 08-15-2010, 02:12 PM
Illiana Chapter Director
How many qts. have you already put in?
Old 08-15-2010, 02:13 PM
you should be fine as long as its on the stick, you dont have far to go & you dont hot rod it
Old 08-15-2010, 02:36 PM
Not sure exactly how many qts. are in it now, thats the problem I had a 5 gallon bucket (with about 1.7 gallons left) from the last change and I knew it wasn't enough to do this change so I just another gallon and figured I be good... Nope. I'll another quart before or after work, My work is about a 25 mile ride so maybe I should get it on the way and pay the gas station too much for the oil ha.
Old 08-15-2010, 02:39 PM
If you have put almost 3 gallons in it then you are still at least 3 qts. low
Old 08-15-2010, 03:26 PM
Powered by Deez Nuts
on my last truck, somehow i didnt pay attention to the oil level and it stalled from lack of oil. the oil stick was clean. 1 gal brought it up to the bottom of the stick tip.
Old 08-15-2010, 03:32 PM
Aslong as it runs and you aren't beating on it or towing, then you're good.
Old 08-15-2010, 04:37 PM
Cool thanks guys, I have read that these trucks will shut down from lack of oil before damage but I just wanted to be sure.
