INITIAL STARTUP - Ford Powerstroke Diesel Forum
Old 08-15-2010, 11:52 AM
INITIAL STARTUP
recently rebuilt my 7.3. tried to start it saturday, unsuccesfully. hooked my supertuner programer up and got code p0603.
fords shop manual p0603 =
Possible causes:
Battery or PCM has been disconnected.
Battery cables loose or poor connection.
Battery discharged.
Open in KAPWR circuit.
Blown fuse.
PCM.
Check for other codes. Key on, engine off. Clear DTCs. Cycle key off, then on. Perform retrieve Continuous DTCs
we checked all the 5 amp fuses - o.k.
the batteries had been out since the end of may. could it had lost all the pcm memory that contols starting.
also is there any initial priming procedures that should be performed that may allow it to be started.
could i possibly install the lowest supertuner performance program in hopes of restoring some type of memory to the computer to allow it to start.
any other help that i may not know about or can find will be very helpfull.
Old 08-15-2010, 03:09 PM
That code is just from having batterys unhooked. What doesit do when you try to start it?
Old 08-15-2010, 03:18 PM
You can try a tiny bit of brake parts cleaner in the intake to help start it. If you had the injectors out, oil takes forever to make it back to them. In that case, crank in 20-30 bursts and keep an eye on how hot the starter is getting.
Old 08-15-2010, 05:17 PM
just turns over like its not getting fire or fuel, i do get fuel to the filter. need to check the rails
Old 08-19-2010, 04:31 AM
ITS LIVES !!!!!!
ELEVEN WORDS THAT WILL HELP THE NEXT PERSON AS FAR AS THE HPOP GOES:
PRIME, CRANK, PRIME, CRANK, PRIME, CRANK, PRIME, CRANK, CRANK, CRANK, CRANK!!!
WHAT IT TAKES TO REBUILD A 7.3 L INTERNATIONAL
HEAD WORK - $560.00
BLOCK WORK/SLEEVED CYLINDER - $1061.00
VARIOUS TOOLS, ENGINE STAND, EXPLICATE INSTRUCTIONS - $600.00
HELP FROM INTERNET FORUMS - PRICELESS
THANKS EVERYONE!!!!!
Old 08-19-2010, 07:40 PM
O.I.F. Combat Vet 11B
pm sent, looks like I am gonna need a rebuild soon...... gonna need all the knowledge I can get
Old 08-20-2010, 07:44 AM
i would love to know how to do this. but i hear its easy with good resources, and i also hear never rebuild a diesel unless your a diesel mechanic from a lot of people. they always cite "due to tight tolerance of a diesel engine..."
maybe im wrong, but seems to me it would be easier than a gas motor...
