Pitman Arm nut size - Ford Powerstroke Diesel Forum
Old 08-12-2010, 08:13 AM
Pitman Arm nut size
Can't seem to find this anywhere...
the nut underneath my pitman arm seems to have loosened up a bit, and I need to tighten it back.
I don't have a wrench big enough though, and want to know what size that stupid nut is so that I can go get one.
Your help is appreciated.
Old 08-12-2010, 08:57 AM
X jbm x let me change this steel on my drill rig and I will go check on mine
Old 08-12-2010, 09:08 AM
mine was doing the same thing. 1 5/16"
Old 08-12-2010, 09:15 AM
yeah, I believe it's 1 5/16"
I'm experiencing a clunk in the front end, and wondering if this has anything to do with it.
The truck's got a recent lift kit, so new springs, and new sway bar end links...
I felt a little bit of play in the track bar, and then noticed that nut was loose, so I figure that's gotta be the root of the clunk since I can hear it in the front, and feel it under my feet and slightly in the steering wheel.
Old 08-12-2010, 09:45 AM
Thats the same thing.... I tightened mine up 3 days ago and the clunk hasnt come back. Dont know if i should take the Nut off and put lock tight on it.
Old 08-12-2010, 09:46 AM
Thanks Erik. Good to know.
A little Lock Tight certainly couldn't hurt.
Old 08-12-2010, 09:54 AM
Its 1 1/8. Or 1 1/4 hope that helps
