Exhaust upgrades - Ford Powerstroke Diesel Forum
Old 08-11-2010, 06:53 PM
Exhaust upgrades
Thinking about trashing the duals in favor of a big single that exits out in front of the pass rear tire. I'll put a turn down so I don't get the bed side blacken'. Anybody have any thoughts?
Old 08-11-2010, 07:47 PM
i had duals, and i had a single stickin out in fron of the rear tire, now i run a single stack. on the exit in fron of the tire, if you take the last piece that exits the driver side and put it on right before the where the muffler mounts it sticks out in front of the rear tire pretty nice. that's how i ran mine for a while before i went stack
Old 08-12-2010, 03:57 AM
Did you have any problems keeping your beside clean?
I notived you're up in Washington, right? I'm AF Ammo/Ordnance at Hill AFB, UT, trying to talk the wife into trying to get up that way, heard it has some great fishing.
Old 08-12-2010, 04:13 AM
no any worse than how black my rear bumper and tailgate stayed when i had full exit exhaust. yeah jblm is in wa, really don't know too much about the fishin i go to wa and deployed a few weeks later but the area is nice
Old 08-12-2010, 03:47 PM
With the exhaust exiting in front of the rear tire, has anyone ever experienced tire failure due to the amount of heat? I was thinking about doing the same, but leary of adding additional heat to the tire. Sorry not to hijack, just playing devils advocate while collecting my own info.
Old 08-12-2010, 07:56 PM
dude you can put you hand on the tip while it's runnin. my stack is right next to my back glass and it won't even bubble the tint. your tire is fine
Old 08-13-2010, 09:28 PM
been runnin mine out the side infront of the rear tire for a few weeks now, no problems with the tire gettin hot and i havent had a problem with any soot gettin on the truck, jus make sure you get it at a good angle where it pushes it away from the truck. youll love it, its sounds amazing when you get on it. ill see if i can find a link to my thread about it.
Old 08-13-2010, 09:29 PM
here ya go!!!!
exhaust.
Old 08-14-2010, 06:45 PM
I'm sure you can put your hand on the exhaust pipe while its running, i mean idling. The exhaust gas temperatures coming out of the pipe under a load have got to be pretty high. The last time I checked, most people installed stacks to the rear of the cab; EGT's were not directly blasting a tinted window. Dude,your window must be fine.
Old 08-14-2010, 06:50 PM
I'd keep the duals if I were you.
