Is this feesable with just intake/exhaust/tuner? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-08-2010, 07:21 PM Thread Starter
kitchene's Avatar
I Just got a 2000 550 for work, towing campers mainly. Is 300hp an attainable goal with just the DIY intake, 3.5" straight exhaust, and a DP tuner? It needs to be 100% reliable, and wouldn't be hot rodded at all.
If not, what other things do I need to look at. I know there are threads all over about mods but none I've seen give clear hp numbers.
Thanks,
E
kitchene is offline
post #2 of 5 Old 08-08-2010, 07:26 PM
no-tel-in's Avatar
Deff, you will need gauges, and everything will need to properly functioning (no leaks, or missing injectors, or low fuel pressure), Also some trans upgrades should be in order, you auto or man?
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #3 of 5 Old 08-08-2010, 07:46 PM Thread Starter
kitchene's Avatar
I'm running an auto. I was under the impression the tranny could hold up to around 400hp, but I was planning on upgrading it when it was due, but not before. Would I need a full on upgraded tranny or just a beefier torque converter?
kitchene is offline
post #4 of 5 Old 08-08-2010, 07:52 PM
no-tel-in's Avatar
nah, you said you will be towing, it wont last!
I would do a BTS or John Wood valve body, Torque converter, and a big cooler, you should be good to 400 then
2000 F-250 4x4 7.3
GTP38r
Adrenaline HPOP
238/100's
post #5 of 5 Old 08-08-2010, 08:58 PM Thread Starter
kitchene's Avatar
Thanks Notelin. May change my upgrade path with this info. Gauges, Intake, Exhaust, Tranny, Chip.
kitchene is offline
