tell me what you think - Ford Powerstroke Diesel Forum
post #1 of 22 Old 08-08-2010, 09:47 AM Thread Starter
addicted to diesel
highraven99's Avatar
ive continued to have a sound in my truck. mind you all that 2 months ago i had the bottom end apart and put new rod and main bearings and check for play in the wrist pins and such. the sound is coming from the passanger side #3. ive checked the pushrods. ive been starting to think really bad injector. when the sound is loud she runs fine and when it quiets down i have a bit of a miss or stumble when im on it. if the attachment works im including an audio recording of it at idle
New member map has been set up here:
Diesel fumes make me horny!!!!
Originally Posted by Big Angry Hillbilly View Post
I hear that Dodge gives you a puppy with every truck you buy, so you'll never have to walk home alone again.
highraven99 is offline
post #2 of 22 Old 08-08-2010, 09:53 AM
shhhhh, can you hear it?
08pwrstrokr6.4's Avatar
all i hear is a possible pulley bearing going out,more than likely a idler pulley.but im not well tuned to diesel engines yet.
Patrick
TAPS Historian
08 6.4L ECSB
S&B intake,H&S Black Maxx,5" Pipe,Trac. Bars
13.77@100.63
OIF 07-08 16 months OIF 10/OND 10-11
Originally Posted by Diesel Tech Mag
All you need is a little knowledge,the right tools, and a buddy's truck to practice on.
08pwrstrokr6.4 is offline
post #3 of 22 Old 08-08-2010, 07:40 PM Thread Starter
addicted to diesel
post #4 of 22 Old 08-09-2010, 10:53 AM Thread Starter
addicted to diesel
post #5 of 22 Old 08-09-2010, 11:30 AM
powerhoghp's Avatar
If you think it is the injector, switch #3 with #1 and see if the sound follows.
powerhoghp is offline
post #6 of 22 Old 08-09-2010, 12:32 PM
Zytek_Fan's Avatar
Quoted: 40 Post(s)
Sounds like a sticking injector...but not too sure...
Back to the blue oval: 08 F350 FX4 CCLB - DPF/EGR delete - Spartan tuner - S&B CAI - 4 in DP to 5 in SP
First truck: Early 99 F350 SC LB ZF6 4WD - SOLD
Zytek_Fan is offline
post #7 of 22 Old 08-09-2010, 03:39 PM Thread Starter
addicted to diesel
That's what I've been thinking. I've had the valve cover off checking for bent pushrods, and put my stethescope on #3 injector and it had an extra noise compared to the rest. I wanna see if my buddy still has the laser thermometer that he was borrowing and see if its hotter or colder in exhaust.
post #8 of 22 Old 08-09-2010, 03:50 PM
Zytek_Fan's Avatar
Quoted: 40 Post(s)
Do you have the capabilities to run an injector buzz test?
post #9 of 22 Old 08-09-2010, 04:41 PM Thread Starter
addicted to diesel
I had a buddy run a buzz test and contibution test right after it started. Passed the buzz test and failed 3 & 8 on the contribution test, but I've read some where here that the gray cps can cause that. That's why I'm asking on here what you guys think. I'm all prepare to drop the money on an injector, but if I can't say for sure my wife will kill me if it don't fix it.
post #10 of 22 Old 08-10-2010, 02:57 PM Thread Starter
addicted to diesel
