Turbo timer question
99F250 Early Model 4WD 7.3L Crew Cab
I'm about to have an alarm system installed this week (Omega Crime Guard 850i5) and one of the options is a turbo timer that can be set for 4 options when the ignition key is turned off... 1. Engine dies immediately (default) 2. Engine continues to run for 1 minute 3. Engine continues to run for 2 minutes 4. Engine continues to run for 3 mintues ... is there any reason that serves the turbocharger to let the engine idle for 1-3 minutes before shutting down? Just curious |
yea it allows the turbo to safely cool down so u dont shut the truck off when its too hot and lengthens the life of your turbo
Might as well use it since it's an option;
Another option is an pre-turbo EGT gauge, you can just watch it until it creeps down below 400 degrees then shut down. |
It's a good option. Until I get gauges, I just let mine idle for 2-3mins after I drive for 30-40mins or more. If I'm just doing my 8 mile commute, I just let it idle for about 1 minute while I get my work stuff together...
Thanks guys. This is something I'll definitely use then.
Would you mind sharing how much the alarm costs? I wouldn't mind getting one either, just curious...
Thanks.
