  #11 (permalink)
Old 05-27-2007, 04:20 PM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
Originally Posted by klookybrown View Post
I too have air bags in the bag and can hear that compressor goin... (was on the truck at time of purchase) You have more info for that setup? Sounds Nice!
Will
well its a lil complicated ... ill be doing a thread on it when im done but required some fabrication welding and alot of cash lol... its not cheap to make a system like this... 2 Viair compressor that feed 2 5 gal tanks.. the control solenoid in cab to control the rear 300PSI air bags... all in all it will be a nice setup but will end up costing me around $1200.00 if not a lil more.... high price to pay to be able to run air tools and air up your tires... i also really want to attach a generator like the one that runs off of our engine.. and get a small portable welder....
  #12 (permalink)
Old 05-28-2007, 11:47 AM
stump0331 stump0331 is offline
SNAFUSTUMP‹^›‹(•¿•)›‹^›
Tournaments Won: 1
What About Belts
  #13 (permalink)
Old 05-28-2007, 02:15 PM
ABOBB ABOBB is offline
Is it even worth it???
Definately keep a cps in the truck.. along with a simple kit for changing it out.. it's easily worth the money.
  #14 (permalink)
Old 05-28-2007, 09:31 PM
klookybrown klookybrown is offline
Send a message via AIM to klookybrown
Originally Posted by stump0331 View Post
What About Belts
ya, what he said. Good idea to carry a spare or just make sure your lady's wearin' her nylons for that real old school trick
  #15 (permalink)
Old 05-29-2007, 07:45 AM
howardtm howardtm is offline
Absolutely BEST thing to carry is very small and cheap..a plastic card that has the AAA logo on it!
  #16 (permalink)
Old 05-29-2007, 12:01 PM
mmmm, I do, I do! But that's also what I want to avoid... Their gonna take me where i'm gonna have to spend money! So if I can avoid it say 2 out of 3 times I get stuck because of a few 'just in case' items, all the better.
  #17 (permalink)
Old 05-29-2007, 12:28 PM
well, lets see...a spare cps is always a good thing, and yep..a belt, cause if that sucka breaks you ain't going anywhere. You want to carry the tools needed to put it on. Myself, I also carry a 1/4" drive metric socket set under the seat...handiest little tool set I ever bought!..also, from experience here...that high pressure hose going from the power steering pump to the boost block...might carry one of those just for schyts and giggles. If that goes, not only can you NOT steer it...you lose your BRAKES as well...took a real genius at Ford to come up with THAT dandy. Had one literally blow off the end...talk about a sudden rise in the Pucker Factor! Other than that..a qt of tranny fluid, a couple of oil..you can't cover everything that could possibly strand you on the side of the road, but some of the more common things. Don't make sense to load up a small parts store in your rig...if its that undependable..ya got the wrong rig.
  #18 (permalink)
Old 05-30-2007, 12:59 AM
rolln22s rolln22s is offline
it is a good idea to make sure you have a 1/4" and 1/2" socket set. also metric and standard wrenches (along with a cam shaft sesor). i have used basically all those tools the past month between taking my alternator off 2 times in a month at the auto parts store and dong cam shaft sesor surgury on the side of the highway.
  #19 (permalink)
Old 05-30-2007, 02:19 AM
rankroddin250 rankroddin250 is offline
if you have problems with your PSD like i have been a good pair of walking shoes is a great investment to keep with you and a spare couple throusand bucks in your checking acct. that you never touch unless you need to dip into it for parts or lift kits,or tires, or chips, or intakes DOH!!!!!! whered all my emergency money go???? good thing i remembered my walking shoes
  #20 (permalink)
Old 05-30-2007, 02:21 AM
ok CSS for sure... but metric AND standard?
I knew my 66 impala was all standard- My acura- metric but ****it this truck is both!?!
1/4" and 1/2"? Howabout a typical 3/8" and adaptors to both 1/4 and 1/2??? Will that suffice?
