TS Location
Ive had my TS 6 pos for several months now but i dont have the dial mounted anywhere, just cant seem to find the right spot.....for u guys that do have TS where have u mounted yours???
mine is still laying in the cubby in the dash with my CD's and wallet. but i plan to install it at the bottom of the dash next to my brake controller.
ts6
i put mine below my light swith, easy install
I have seen guys squeeze them on the back side of a gauge pod on the pillar. Kind of pointing to the passengerside of the truck. It fits nicely on the side of a Quadzilla Commander gauge pod as well.
I put mine where a toggle had already been mounted just to the right of my steering wheel. The guy who had my truck before me had strobes in the turn signals and the brake lights. He worked on roads.
I took the toggle switch out and put on my chip dial. It was a perfect fit. |
thanks for the ideas, ill let ya kno what i decide
Next to the cubby hole on my truck there is a switch blank that is used for the sliding rear window(I think). I poped out the blank drilled a hole installed the turn knob reinstalled the blank. It is in the perfect position for me to reach down with my right hand and turn it up depending on who is next to me at the red light
some drill a hole directly in the dash right next to their 4X4 switch
nice to have both in the same location at a stoplight
The TS adapters are now out, so if you have a Commander you can completely loose the TS switch!!
i stuck mine inbetween the bottom corner of the steering colum and the top of the removeable panel. its just wedged in there.
