No electricity every once in a while - Ford Powerstroke Diesel Forum
Old 07-25-2010, 03:14 PM
Once or twice a month I'll hop in my truck start it and I wont have radio or windows, I have to shut it off and turn it back on usually about 5 times to get them back. What can I do to fix this?
Old 07-25-2010, 03:26 PM
Powerstroke Techie
When you loose windows try turning your key back just a smidge towards off and see if it comes back to life. This happens with my parents econoline every now and then.
Old 07-25-2010, 04:30 PM
This happens to me as well and what i do is just open and close the door a couple times and it usally kicks back on. Would really like to know what the problem is though!!
Old 07-25-2010, 11:24 PM
agreed..mine does this too..slam the door and it works..or one day i got a better one for you
plugged trailer in..radio was fine, opend glove box radio and windows shut off..closed glove box ..nothing..unplugged trailer worked fine..repeated same issues..then it went away lol hasnt returned since LOL
ghost..i swear!!
Old 07-26-2010, 12:30 AM
Its only the windows and radio that aren't working at that time, are you sure nothing else? Lights, horn or anything else on the accessory circuit?
Old 07-26-2010, 12:59 AM
s.c s.c is offline
it sounds like u have a bad ground
Old 07-26-2010, 08:00 PM
Happened again today. No radio or windows. Opened and shut the door like 5 times and turned the key back and forth a lot, ended up cranking up the truck and shutting it off about 8 times. Where do I look for the bad ground?
Old 07-26-2010, 08:04 PM
Gem module... Its gotten wet... It will die before too long
Old 07-27-2010, 10:54 AM
Mine does this also, what is the Gem module?
