IAT sensor needed - Ford Powerstroke Diesel Forum
Old 07-20-2010, 10:20 AM
IAT sensor needed
Anyone have an IAT sensor laying around? If i can find one I want to mount it in the return IC pipe right before the Y pipe to see if wrapping the IC pipes makes enough of a difference to offset the cost. I would put it on a switch with the one in the airbox to monitor the temperature split between the two. Wrap the return pipe and monitor the temps, then wrap both and check temps.
Old 07-20-2010, 04:20 PM
i have a stock push in style but itll blow out of the pipe. you need a screw-in one from a 99 up lightning. iirc its 3/8'' or 1/2'' npt. i do have a few extra pigtails though cause i think ford sells it for like 15-20
