Before I BREAK something........
My Cruise Control works fine with the ON button, but it doesn't turn OFF with that button, so it needs fixing.
Can I use a screwdriver to pop the rocker off the steering wheel or is there another trick to removing the On/Off rocker? And is the failed OFF button a fixable thing or do I need that whole dam assembly? |
i dont think i ever used the off button in 3 years? press the brake?
yep, that works fine...but do you know how the guy following me feels when he sees a brake light coming on in the middle of the highway????? ![]() I'd rather not rattle anybody's cage with a brake light. I use cruise all the time, so having it work right is important to me (and to the guy behind me). |
You can't repair the button. The airbag has to come out to remove the button. I think they come as a complete set.
well, that sux. So there's no way I can pry the rocker off without destroying it? If I can get it off, then I can try some contact cleaner on the innards.
I'm sure you can pry it off but it will break and I don't think you can get to the contacts anyway. The switches have wires that run out of them and plug into a connector under the airbag.
Thanks for the intel, dhanna.
No problem.
