Rear End Question - Ford Powerstroke Diesel Forum
Old 07-17-2010, 07:19 AM
Rear End Question
What should i use to seal the rear diff cover to the housing? silicone type stuff, gasket, ???? i had a new rear end put in a few months ago and it is leaking now, and want to get it taken care of. thanks guys
Old 07-17-2010, 07:58 AM
Other vehicle is an F250
Blue or black RTV. I just redid mine and found out that there is a gasket for it. Got it from O'Reilly's.
Old 07-17-2010, 08:04 AM
is the gasket better to use than RTV?
Old 07-17-2010, 08:18 AM
I used RTV last time 'cause I never thot to look for a gasket. It did start weeping. Gasket is doing good. I put a thin layer of black RTV just to make it easier to keep in place. Seems to be fine. I vote for the gasket.
Old 07-17-2010, 08:22 AM
Thanks for the info Hank.
Old 07-17-2010, 09:04 AM
I use both. A small bead on the housing, then the gasket, then a small bead on the cover. Tighten cover then wipe off the excess.
Old 07-17-2010, 12:01 PM
thats what i just got done doing. put a bead on the case, gasket, then a bead again.
Old 07-17-2010, 12:12 PM
use both! Most importantly prep the surface on both sides with a solvent and then use an emery cloth to scratch the surface down to clean metal
Old 07-17-2010, 12:35 PM
O.I.F. Combat Vet 11B
I just cleaned it up really well and used black rtv when I did mine
Old 07-17-2010, 12:37 PM
That is the key!
